R6 Exhaust Marthy Edition
Strongly suggest you PCV. The main reason, I will give you the MAP. If you look in this post there's a clip from the Supertrapp. And I'm sure you can find one of the Viper can. I will sound about the same. I will make a clip of the Viper when I'm done with it...
Ah ok. I thought they wouldn't sound quite the same with a different header. How much does the PCV cost? It's plug n play if I remember right? (well close to it anyways?)
Marthy,
I understand the Supertrapp restricts depending on the spacers and that is how you got around the longer pipe issue to increase port scavenging. You can't do that with the Viper.
Once you add about 14 more inches of pipe and get some length, you will see what that does to the midrange.
While riding today I noticed my front end was really light a bunch of times with only a 50% throttle in 2nd gear and only at about 8K to 9K.
This gets me around obstacles (cagers) in a heartbeat.
I'm still using the stock M4 map btw...
