Oh dear... Love it.
wow, great sound, yellowfz is right, maybe you could make this into more than a hobby
Just a observation -- but aren't those O2 sensors way to close to each other? Wont they cause a turbulence and false readings or DTC/MIL event? Been my experience with O2 sensors in exhaust tracks that subtle things can affect them greatly. Were they that close in the original exhaust, before cat, after cat? (cat) is catalytic converter. No way on these ECUs to delete O2 sensor or set to not report, do not trip MIL (check engine light).
Where did you get the 3-1 merge collector?
Seems like a simple build.
Little video of me tuning the bike. Notice at 3:30... far from being WOT! That bike is sick!!! That was safely done in an empty parking lot by the way...
FZ-09 / MT-09 Marthy Exhaust under real life tuning - YouTube
Of course I don't have to tell you you probably know but for others 14-15 is okay, 12-13 is for power at WOT, misleading, idle can be 15-16 easily (I run 16.1 under cruse, I mean highway cruising, no load all the time, called Lean Cruise), of course I have only been tuning ECUs since 06 and not 32 bit ones but 1-2mb ECUs and using UEGO to do Lambda and EQ tuning. 14.71 is stoichiometric (best burn rate) for those that don't know, what all narrowbands strive to achieve.You might be right, I try to space them as much as I could with the space that I have. The bike only use one... the other one is the Autotune, I use it as very expensive O2 sensor read out! LOL also log data with the LCD-200. The bike run way too lean all across the board. 14's and 15's pretty much all over. The ECU/O2 only work under 15% throttle or so (ECO mode on the dash) and trim it down to 14.7:1 for fuel economy.
The build is some how simple. The tube available are in between what I really need. So I'm trying to figure out the right combo... I would like the can a bit more upward without hitting the brake pedals... but if this is the best I can do... I'm fine with that.
The hardware is twice as expensive as what it cost for the 6R but I don't have to deal with the shipping back and forth.
Any one heard/rumor that the 09 has a governor...top speed 130'ish ?
