redprodigy35
Ok so a quick story I thought I'd share with you guys.
Got on the bike yesterday and realized its been about 2 weeks since I checked my tires. I go over to my local Exxon, and put in 4 quarters to run the machine after I double checked that I was indeed low.
Topped off the front and back, I run 33/36. The front was @ 34 so I thought that was good enough, and the back (after I checked with my crappy gauge) was (I THOUGHT) @38. This is fine, I'm like cool it'll go down to 36 eventually and give me more time between air fills. Whats 2 PSI extra for a few days right? Later on I'll find out I didn't get a good seal with the crappy gauge and my reading was way off.
So la la la -- I go out to some familiar roads in the area with some limited twisties. One of my usual spirited riding routes...
Something was wrong -- very wrong. Bike felt stiff, took longer to come to a stop, all in all an awful feeling of "something is way off here".
I get to the twisty section and there is this one corner with a decreasing radius, blind setup. One of the most challenging corners for me to hold a good line while riding at a brisk speed. It's a commit fully or re-adjust awkwardly kind of corner. I love this corner, but it IS challenging for me. I must have taken it 200 + times by now, always working on my technique and keeping aware that I am somewhat pushing MY limits as I take it on.
I'm mid corner, I'm leaning, steady throttle increase... REAR WHEEL SLIPS. I instantaneously correct without thinking. I'm just about to let out an exhale to relax, when it happens again!
HOLY BANANAS (#&$%)!
I pull over 2 miles down @ a spot where i usually take a quick smoke/water break. I check the back tire...
48 PSI :zombie:
I think I could have easily popped it.
I let some air out and everything was fine for the ride back home.
Don't rely on made in China stuffs even if they are simple as a psi gauge. Double check your setups, and keep in mind that even routine maintenance and regular everyday stuff (safety checks) needs to be done thoroughly.
48 PSI :zombie:
