Thanks for sharing!
You are a good person!
bye.
Best map, you'll never change it until you change to another bike.
Thanks for sharing!
bye.
I been searching this site for a map that would satisfy having TBR exhaust and juice box with a moded airbox would I fall into the REV B category? Thanks in advanced for the assist.
Sweet thanks a bunchCan't run Advance Gear maps on the Juice Box. Best map for JB with TBR exhaust is Sport Rev A.
Might have to try a touring map. On AdvGearRevB I've averaged about 34mpg on the last 3 tanks of gas......
What can I say? The sound and feel of bringing the needle up in the first few gears is intoxicating :leghump:Probably because you twist the throttle a little more. LOL! I am still averaging in the 40's with advgear rev b.
Only available for the PCV.So i just flashed Sport Rev A into the Juicebox of my 6R that has a 2 Bros can. Everything went well and i'm excited to take it out and test ride it. My first question is when i go to send the map in the toptune software it lists 3 options as i've read here, Advance, Intermediate, and Novice. I would like to stay in the intermediate range, my question is how do i know which version off the ACC Pump feature of the map is flashed? or is this a feature only of the PCV and i don't have to worry about since i have a Juicebox Pro? Thanks in advance.
But the map will still work for the juicebox correct?Only available for the PCV.
Yes, it's the best map or jbp.But the map will still work for the juicebox correct?
That's usually what I average as well. On a "good day" i might get 40Might have to try a touring map. On AdvGearRevB I've averaged about 34mpg on the last 3 tanks of gas......
in the zero columnn try -3 from 1000 to 1500 rpm and check when the enfine is up to temp. From cold to warm them hot the idle fluctuate a bit... but once hot it shoild stay at 1300ish almost steady.Been running the Sport Rev A on my 6R daily with a Juicebox for 2 months now and i definately love it. Changed back to the Juicebox stock settings once but hated it, bike just didn't feel the same. Once i got over the irregular idle, the bike perform very well with the 2 Bros exhaust. Still haven't figured out how to overcome the idle jumping between 1k-1.5k constantly at idle though.
I haven't heard of doing this. What purpose does this mod serve? It sounds like a bad idea.I also just today blocked off the crank case ventilation with a small pod filter and plugged the air box inlet,
The Advgear RevB is the best map for your set up. The speed sensor need to be hook up to work. I mess with the temp ensor back in the days... no gain to get there. And please... plug back in the crank case vent before you blow up gasket. Theres a lot of pressure in the crank case and sucking in up in the intake acually help HP better that just open to the air.Marthy I've got a stock motor but running a two brothers exhaust, I've ordered a PCV and some block off plates, I also just today blocked off the crank case ventilation with a small pod filter and plugged the air box inlet, I have two questions after reading this thread, if I have no O2 sensor anymore because of the tb exhaust and I bought and o2 eliminator like this one Oxygen Sensor O2 Eliminator Yamaha FZ6 FZ6R FZ1 FZ1N FZ8 FJR1300 | eBay , how will these changes effect the maps you have created?, you said the speed sensor has to be hooked up to get the maximum out of advgear rev b, what about the temp sensor is that required too? I wonder if there is a map that gets the best out of the bike over a 1/4 mile no matter how many L/100k it takes Thanks mate
