Would be a ticket here putting the plate under like that. Cops around here don't like that at all. I'm guessing it's not a problem where you live.Here is my tail with the required space in between the indicators
Not sure if you can see, but i got LED strips and hooked them up to work in with the integrated tail indicators + got rid of the FE all together
His plate isn't a fender eliminator it's in the wheel well. The shop where I was inspected loved my comp werkes fe. They thought it was custom. Most cops won't care as long as the plate is visible.I use DMP Fender Eliminator kit with a integrate d tail light it looks nice and flies under the radar with cops.
G'Day mate,Here is my tail with the required space in between the indicators
Well i weigh about 80 kg and ive got other people to sit on it to try and see how it shows from behind im not saying that theres no cops who would pull me up (and considering im studying policing i probably should be leaving less up for some angry highway patrol to pull me up on)G'Day mate,
How mch attention do you cop with that plate set up? Unless you weigh about 40kg when u sit on it you would hardly be able to see it would you?
Ever been up the old pac or putty with it and run into the boys in blue?
Looks trick, but if I sat on it you wouldnt see the damn thing!(115kg)
I purchased an R&G FE, works nicely, holds the plate out a little behind the tyre so I can still fit my P plates.
yeah same problem, cuts the things in half, she sits down with me on it. Got pulled up Sat for stat RBT setup, he laughed asked how the pinlock fog visor was, and see u later. prob lucky im older aswell, got a magnetic one to tie on their, but havent got around to doing it. it "should" stay on???in saying that i honestly couldnt fit my P plate under my old FE without it flipping up on the wheel so i re-located it, bare in mind this photo was when i ran out of zip ties and it was kinda crooked but normally it looks pretty visible if i get pulled up on it i might have to check out the FE you got.. bloody P plates
