My first problem with my ducati
leprecaun jon
ESTABLISHED RESIDENT
AL72
Your bike blown a fuse several times and you replace it with a bigger fuse? If so, do not do it any more, you can fry the ignition box.
Good luck!
Chris12
Is the aux. fuse box OEM, or was it added aftermarket by a previous owner to power accessories (maybe extra lighting, USB/power outlets, heated grips etc..)?
If it's aftermarket I'd check in to how it's wired. Also if you have a battery tender sae cord wired in, check that too. It's likely that a powered wire is grounding out somewhere, arcing and blowing your fuse.
I'd look for rodent evidence too, those suckers love to chew wires.
As the previous member stated, those fuses are protecting your bike from too much current flow=heat melting your wiring. They are a good thing.
Good luck!
leprecaun jon
leprecaun jon
leprecaun jon
leem00
Sport touring Member
leprecaun jon
leem00
leprecaun jon
fazer1
Coolest looking naked bikes I've seen are the Monster and a few years back, with aftermarket double headlight. That was my inspiration for my fz6r, although I have a single LED headlight and a small flyscreen.
I love Yamaha, and the idea of the FZ10 is great, I love the engine, but I don't like how it looks like a transformer. My only complaint.
