For those who are thinking about using the ZX-10R mirrors with the integrated turn signals, they do make Y bullet connectors that you'll probably have to order online. Conversely you can make your own using a soldering iron (which is what I did) using the Custom LED OEM wire harness. The reason I'm commenting is that when I replaced the front turn signals with LED flushmounts that were also wired with the integrated turn signals, the blinker rate synchronizes with the tail lights just fine without having to use a replacement LED flasher relay (so save yourself the 20 bucks).the issue is a 3 way split connector is needed
if you both want to run the original flashers, and the flashers in the new mirrors. doesn't seem like such a thing exists
Yes I tried those (inspector said I needed frontal visibility for turn signals and my flushmounts weren't enough) and they were horrible. Go for the standard ZX6R mirrors 05-08 range as they are direct bolt and are way more functional, but not signal mirrors. Just add led's in the front scoops like a lot of us have so you have forward visibility of your signals.I think Scott bought these at one point but said the visibility was dreadful.
Hey guys what are the bolt hole measurements on the FZ6R stock mirrors
Or
Year range of zx6r mirrors will fit eg 2009
Oh thanks man did not check my other reply what about the 250r mirrors any idea?05-08, but there may be other years as well.
Yes, no drill. Not sure about ninja 250 mirrors.Sorry if this is the obvious question so are zx6r mirrors a confirmed fit no drill required?
Also does anyone know if the ninja 250r mirrors will fit no drill required ?
