what's one thing you tell yam fix on the 6
  • Thread starter Thread starter whatever
  • Start date Start date
W
whatever
I have to say the vibes......some days seems worse then other days.. need to resync my carbs again.
I wonder where the vibes come from... i know it's in the motor somewhere.. but what could be out of balance to cause such a vibe.
I may trade back up to a 1000 or busa next year not sure.
but for 5149 the bike was a steal.
Probably the exhaust. I have the stock exhaust still because I'm too lazy to change it because it requires "significant" effort.
What vibrations do you have? On my bike, at 7K, the foot pegs vibrate a bit, but I never gave it much thought. The rear seat vibrates a bit as well, I never looked to see at what RPM though.
Ya...significant effort is right...LOL
there's a little vibe around 6/7 rpms then the motor smooths out.... on my bike anyway but now mine is picking up just a little in the 5 thousands range so i need to resync my carbs... been about 4000 miles so they must be do.
the only mods i made to my 6 are a carbon tank pad and some gel grips which seeem to help a little.
i like the stock exhaust system it's out of the way and..... it looks kind of cool...easy to clean you just wipe down the chrome tip.
yea you have to run below or below the vibe which is a pita sometimes.... but i use a little trick sometimes if im running on the highway....
i will run the thottle at 5000 rpms and run up to 7000/7500 and then when comes back down i will run back up.... kind like when your breakin in a new motor... so you don't notice the vibes as much by doing this.
my bike has the 43 rear sprocket which helped alot .......i agree.
with all the bikesi have owned.... i perfer to keep them stock now a just add oil an gas when needed
sometimes they run better stock if you leave them alone and don't touch anything..... but yes you can make the motors get more air and fuel and they will run faster ..... but sometimes they with be more tempermental.
what do you mean by harmonics.... can you explain better in layman terms.
web tv is no longer compatible with you tube but thanks for trying.
they added too much informations they knocked us offline 6 mounts ago.
i understand now thanks.... but how come honda never seem to have them. lol
i see i have seen bridges dance before... i know what you mean.
yes i agree..... that was my 2nd choice......the 2010 model cost close to 7500 so you think stuff like that could be added.
i knew bike prices were getting out of control when 600 start costing 10 grand.
riders will go with bigger bikes for almost the same price.... thats why suzuki imported no bikes last year they had so many left overs...now with no money around.... like before their prices with have to reflect the times.
were i live in upstate new york most bikes are discounted between 1500 and 4500 hundred dollars.....
