- Admin
- #21
:thumbup::thumbup:
Question, My kit came in today and I noticed there were two ballast.. I have no idea how to install this thing and the instructions don't help that much...
So do I have to use both ballast or just one?
You just need one. If they are attached (mine were), they suggested just cutting one off.
Finally! Finished after 6 hours!
I just installed it with both. My Hi and Low beams work, I think if you just install one then it's just the Low Beam.
The little white/black connector is the switch btw.
Paid off, for sure, now I just gotta re-aim my headlights... hopefully I don't have to remove all those fairings again?
Use a 5/16" (or a 8mm I think) socket and you can reach the up/down adjustment without removing anything. It looks like a dull quarter with a 5/16" nut in the middle. I was able to hand adjust it grabbing onto the socket. I just raised mine up a bit. I put my bike on the rear stand and put up a piece of tape at the top of where the light beam is before adjusting to give me the starting point. I then adjusted the beam line to about 1 inch about the tape for starters. Tomorrow when I ride in the early morning darkness, I'll see if that was enough for me.
It took you six hours?! I had gotten the impression it was a little harder than changing the bulb and mounting the ballast. Was it more involved? I've been contemplating this mod for awhile. You still doing a how-to write up for this?
You must have gotten a different model of light, then. Mine is one bulb that moves forward to re-focus as the hi-beam.
Glad you got it working.
Did you get the one from custom dynamics? for like $159 - with the adjustable optics for High and Low???
H.I.D. Motorcycle Lights HID Motorcycle Kits
No, I went to DDM Tuning for @ $80.
Don't remeber the exact ones, but here's a link to one of them: DDM HID Kit Slim Ballast (35W or 55W): HID Kits, DEPO Lights, BMW Bumpers & Lighting - DDM Tuning
Apparently, they're on sale too.
I think it was this...
DDM 35W & 55W Single Hi/Lo Motorcycle HID Kit: HID Kits, DEPO Lights, BMW Bumpers & Lighting - DDM Tuning
Edit: Also on sale for 50% off...I may have to find a way to get this...
