Hello all,
I want to be able to use the gps on my Nexus 4 while I'm riding. I believe I need some kind of mount and a special charger. Could anyone reference me to some mods for my Yamaha 2009 FZ6R?
Thanks! :zombie:
I use the LifeProof case and bar mount. And the car charger for it.
RAM Sealed Enclosure Medium/Wide Size AQUA BOX®
the aquabox does, you cut out a pre shaped hole through the back of the case where the wire goes through some channels(to prevent water from getting in the way the cable is). Then the back mounting plate is screwed on so the wire is secured under the plate. I RTVed the holes and the circumference of the plate to prevent any possible water getting in.
So with the microUSB port being at the bottom of the phone and the hole for the connector in the back of the Aquabox, doesnt that cause problems with the phone fitting in there?
Hello all,
Thanks! :zombie:
ram mount x grip
