June 11th 2013
Hmmm.. Yeah. Do not think this and the FZ8 can go side by side? One or the other will probably go away. Most likely the FZ8?
I like it though... Something I could see myself on. I like the naked ones. Curious to see how the reviews stack up on it.
bleedinblue
aki
MT-09 Darkside of Japan
Japanese promotion video
The NEW Yamaha MT-09 (official video Full HD) The Dark side of Japan - YouTube
Engine highlights
• 850cc liquid-cooled 4-stroke 3-cylinder DOHC 4-valve
• ‘Crossplane philosophy’ for linear torque output
• 115hp @ 10,500rpm
• 85 Nm @ 8,500rpm
• 78mm x 59.1mm bore x stroke
• 120º crank with firing sequence at 0º, 240º and 480º
• Forged aluminium pistons and direct-plated cylinders
• Newly-designed 6-speed transmission with compact clutch
• Yamaha D-mode switchable mapping
Tech Specs
Engine: Liquid-cooled, 120-degree, 847cc (78 x 59.1mm), inline triple, 12v, 6 gears, chain drive.
Claimed power: 115bhp @ 10,500rpm
Claimed torque: 62ftlb @ 8500rpm
Chassis: Aluminium die-cast sectional frame, aluminium die-cast asymmetrical double-sided swingarm
Suspension: Front: Inverted 41mm fork, rebound adjustable Rear: Link type monocross with horizontal shock, rebound & preload adjustable
Claimed kerb weight: 188kg
Brakes: Front: 2 x 298mm front discs with radial mounted 4-piston
calipers. Rear: 245mm rear disc with
pin-slide caliper
Front tyre: 120/70 R17
Rear tyre: 180/55 R17
Fuel capacity: 14 litres
newfz6rguy
I know in England it's going to go for $6799 (pounds of course), and if it's anywhere between that and the FZ8's price, I will definitely.....have to beg my wife
bleedinblue
MNGreg
waiting out winter
Alex6
Been driving all day. So here's are my tough. So Yamaha duplicate the StT but needed 175cc more to get the same ponies. HP is within what the FZ8 pull, event less if you do the R1 cam swap. Only + is the 30 lbs or so lighter. Do those 30 lbs worth paying the price of a FZ1 with 20HP deficit?
I think the bike will appeal to the Yamaha fan base but if you take a step back and think about it... they are not even close to be able to get a killer on the market with this bike.
At 10K there's better I think. If you consider that Yamaha is not renowned to get there bike all sort out straith out of the box... so add another $1-2 K...
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
At close to $10K the Z1000 makes much more sense, IMO...
Fizzer6R
Fz9
the prev. info is euro spec, for us:
Production of the 2014 FZ9 has already begun, and suggested retail price of $7990.
Sage
or the the Triumph Street Triple lol, or even the MV Agusta Brutale 675/800
All for about $10k also, but it looks like the FZ-09 is $8k
bmw675
This bike sure doesn't wow me. The specs, marthy already pointed out, just do not wow/impress me one bit. And I think it looks ugly as well. Not a fan of that style of tail.
Just all around not impressed. Just don't see how it fits in compared to the current lineup.
