Tools/Materials required:
1. Allen Wrenches
2. Wire Cutters
3. #2 Philips
4. Angle Grinder
5. Black Paint
6. Welder or JB Weld
7. 10mm Socket or Wrench
8. Welding clamps or Vise Grips
Directions:
1. Remove 4 Allen bolts below the seat that are under tool kit.
2. Cut the wires, but give your self 5-6 inches of wire.
3. Now remove the 3 wire zip-ties.
4. Unscrew the back 4 philips screws.
5. Separate the fender frame from the plastic cover.
6. Unbolt the license plate mount.
7. Cut the fender frame with the angle grinder.
(Sorry didn't take pictures of this part)
8. Cut the top center section of the license plate mount.
9. Clean areas to be welded with the angle grinder.
10. Weld the license plate frame bolts to the cut fender mounts.
11. Paint
11. Install
1. Allen Wrenches
2. Wire Cutters
3. #2 Philips
4. Angle Grinder
5. Black Paint
Directions:
11. Paint
11. Install
