Marthy's PCV Maps
ignatz
No gear position
It appears the speed sensor is working, when I unplug from the PCV it the speed is no longer displaying when running the Dynojet software. One thing I did notice was my gear position never changes from 0 regardless of what gear I'm in. I think that might have to do with the issue I'm having. I looked at gear calibration but I'm not sure how to properly set it up and the instructions are very vague. Has anyone had an issue like this or know what I need to do to set the gears?
Thanks
Nick
ignatz
Looks like the gear calibration needed to be done. Once all gears were set I took it for a test ride and what a difference. Thanks Marthy!
chopper71
Getting ready to install my PCV and I hope I have picked the right map. I was going with Advgear RevB. I have a TB full exhaust with block off plates but no air box mod. I do have the speed sensor wire already hooked into the pink wire coming up from the shifter side. So please could someone let me know if this is right? Still waiting for the mail to get here that has my PCV. So I have some time to correct anything that may be wrong.
xtina
Where are the maps? The links in the first post don't work. I wanted the touring revD map for fuel economy with my tbr and pcv.
Zinx
So I downloaded the viper can sport/touring map. But my bike keeps dieing whenever I pull in the clutch and bring it to a 1k idle. Any ideas? I have a custom m4 exhaust on my FZ6r (the slip on for r6) and KN filter.
:zombie:
5TAZNA
You can't use the Advgear map with TBPro. But you can achieve the same result.
1. Sport RevA
2. Touring RevB or RevD
Since you can swap map on the fly...
Hi Marthy been following this thread awhile and just wanted to ask, would i use the maps above for my setup as well?
1. R6 headers with Akrapovic Megaphone (which is pretty much straight through)
2. TB Pro Juice Box
3. O2 sensor installed
4. K&N filter
5. Running Aussie fuel 95 or 98
6. Half freeway riding and half city riding
Also are there new link locations for your maps as i can only find the ones on your website. I'd like to try out the Touring maps so if possible can you email them to me or post a new link.
Thanks
