So I rode yesterday before re painting my bike again. Got a lot of bad backfire. Got it on accel and decel. Here is what I'm running.
Two Brothers full exhaust no leaks
PCV with Marthys Advgear RevB map
Drilled holes in air box
Blocked off the original AIS
Have you just recently installed/changed anything or have you been running fine and it just started?[/QUO
Everything was just recently installed. Maybe a couple of weeks ago without much riding since installed. The weather being the way it has been, plus having the bike torn down for painting. Nothing more has been done since I've added everything that I listed.
Did you try downloading the two brothers map on Power commander website.
it may help.:zombie:
Once I have it back together I may try the TB off their website.
That would be the first thing to do. Let us know. I know what you mean with the weather it seems like its never going to give us a break.![]()
I see you are in VA. what part?
Im in King William. Like 5 miles from Kings Dominion. What part are you in?
did you wire up the speed sensor input? If I remember right, that map needs it to determine what gear is running
Hey dart thank you thank you for your suggestion. The speed sensor wire was indeed not fully plugged in. I went to check it and it looked plugged in at the pink wire splice. So I tugged on it and it came out. So this time I made sure I heard the connection snap when I put it back in and wrapped with tape. Went for a quick test ride and NO BACKFIRE :iconbeer:
So many thanks to you bud for the suggestion.
