aquestionpoint
Linkgt, If you are in N or with the cluch pulled in and rev it a bit then just cut the throttle, does it die? I had a bad power commander, It was driving me CRAZY! There's a few old threads with people who had the same thing as me. Dyno Jet just replaced it for me and it totally fixed the problem. Make sure your PCV has the lateset firmware update. Search around for that. Check Marthy's PCV map pages and make sure you have the approperiate adjustments for the 0% throttle. That may help also.
Your problem does sound different than mine because of how you describe it. Your dad may be onto somethig with fuel delivery also. GL
