For some reason they have the H4 mount crooked...stupid...Never mind It figured it out. Stupid Yamaha for messing the mount up.
Just a heads up... don't wait until you need light to check how much brighter it is... do an alignment check!
My bike, stock, was pointed way low... it's supposed to be something like at 25ft from a wall, 28-34" where the line is... mine was at about 10-14".... you cannot see with it that low. The adjustment is easy, bottom bolt on left side (as sitting on bike)... Once adjusted, it is amazing!
this is the line drawn in your sight with the low beams in theon pos.
I have never had a problem with a bulb not firing. My only suggestion would be to double check all of your connections to make sure they are secure.Don't know if this had anything to do with it but when I first looked at the bulb it seemed to have some yellow residue inside.
How did you fix it? i'm trying to do all the homework i can for a smooth reinstall, thanks.
I got approval from the local pd on the red aslong as it is switched off when riding. Give me a week or so to get the contract work payments in and this is my second to last mod...If you have yet to send your headlight to me, please get in contact with me. Thank you!
Yeah, that is generally what I tell everyone to do. Switch it and you're good.I got approval from the local pd on the red aslong as it is switched off when riding. Give me a week or so to get the contract work payments in and this is my second to last mod...
If only i could get one installed on my wife!A switch fixes everything....
really only needs 3 settings, normal, shut up, and hornyLmao.... When u find a switch that works let me know I need one too.... Lol...
I finally got to hook up everything today. Looks great, but few questions. Sometimes I have to flick it between high and low to get it to come on, and second there is no high beam at all. Is the right or did i mess up the wiring somehow?
pm sent....new quote requested... I should have tax return for the light in the next 21 daysI have had/used it for years. Never any issues.
I responded
