Botty12
Walked by it. Broke 7000km the other day in p***in rain...but yeah. winter tires on cars means no riding for this 6r.
I rode the 6R to work today. Adding 85 lbs and loosing 30HP & 20 ft.lb of torque all at the same time... make the ride a little less exciting.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
did somethin stupid... while changing the oil i over torqued the drain plug a bit too much and cracked the pan slightly:wtfgun:.... crapped my pants for a minute or two and then said screw it and took it apart. all in all its an easy project to do, as long as youve got someone to weld aluminium. guy down the street did it for $40, which i cant complain about for him dropping what he was doing at closing time none the less..now ive gotta say i am a mechanic and have not ever once cracked a pan from tightening a drain plug..better on something that i own than a customers. good news is, for 8k on the odometer the internals looked great
Performed my first chain cleaning last night. was amazed how much gunk came off and how shiny it looks now. Review of the packjack coming later.
Cleaned and lubed mine too! Especially after the rain we rode through yesterday. Also did the front led strips.. It was easy like you said.. One I had before was just faulty because this one works great!
looks great, I don't know how you got those black ones to bend in the right direction there. I wound up using the clear a little more inside and running the wire through the scoop because they bent in the right direction if you know what I mean. Anyway looks good, certainly visible which is never a bad thing!
Thanks! I wanted to run the wires thru there too... But The wires didn't reach..![]()
I put the light smoke zero gravity db on this week, mine is white and red, it looks nice. Now I'm looking for wind stop gloves because I think I have to take the handguards off, they hit the windshield
Sent from my HTC6435LVW using Tapatalk 2
Found a stand with a platform on wheels that will fit in my garage and get the bike off the ground in 2 simple steps. Only an 1hr drive from home.
Motoglide for use with Superbike Stand - abba Superbike Stand for Yamaha - Abba - Stands and Trailer Restraints
