How deep is the power crystal? Can you fit a bulb in there? Perhaps a Mini H3?
Cool, hopefully he chimes in, I want to install a shielded HID bulb in there.
The aussie model has a bulb in there as a running light.
Yeap!
Still an FZ6R down here.
Though the wiring will most likely bit a little different - some splicing and you can fix that!
Wouldn't have the foggiest idea what the part number etc is - i could do some ringing around if you'd like but I found this!
http://www.600cc.org/forum/f91/turning-power-crystal-into-running-light-14697/
Too shallow for an HID bulb. LED is your best bet. I got your pm, and responded. It does work really well with the Jam Straight bulbs. You can also get colored bulbs from here:
Custom LED Automotive LED Bulbs
This is the socket that you need to get:
Dorman/Marker Light Socket (85814) | AutoZone.com
You'll also need I think a 3/4" drill bit.
Yea, wish I could find the part to see what bulb it is. I couldn't find it anywhere. Is the Aussie also called a FZ6R? Maybe I can find the part.
so i went through the UK parts catalogue...after some back and forth its listed under the model XJ6F(A).
hope this works!
Im sure if you took your part numbers to your local yam dealer they could sort you out.
Think I may have to go ahead and do this mod since it is relatively cheap and not too complicated. I should get the red bulbs and people will think I'm the PoPo with my blue angel eye. The blue bulb would look great in there. Custom LED is the same place that made my magic blinkers for my running light mod (front flushies). Can this be done without actually taking the headlight off?
Possibly. You may have issues getting it straight. Just follow this how to:
Pod Mod - Lights! - Yamaha FZ1 Forums - International FZ1 Motorcycle Community Forum
I think I'm gonna mod whore this one up. Will the maddness ever stop? LOL! Thanks Chad!
