alaskanflyboy
Premium Member
45f & 48r ???!!! was that cold or hot? if those are cold temps, then they are waaaay over-inflated for street riding. i think max inflation specs are 36f & 42r measured cold...![]()
for normal, everyday riding it will go up a few psi from road temps... so, even at 36f & 42r measured cold, u are still technically, on the high (over-inflated) side, because once you've been riding around they will get to like 39f, 45r hot...
unless you weigh over 200+ lbs or are carrying a passenger every time, there should be no reason you should be inflating the tires that high, imo... it will lead to premature wear and not grip as well...
From my understanding, the numbers account for the pressures when they've heated up. The max of 36/42 takes into account the real pressure they'll have on the road. I could be wrong, but that's what articles I've read have lead me to believe.
I've also been lead to believe that the low setting is supposed to be a comfort compromise, you get less rigidity in the tire which softens bumps, but leads to faster wear and tear.
I could be wrong, and I'd have to search through the articles I've read to find the info again.
