DO NOT use Goo Gone!!!!!
danieljardim
He was talking about brake cleaner not brake fluid. Yeah brake fluid will definetely instantly eat right through paint.that's why you gotta be careful when bleeding brakes and adding brake fluid to the reservoir.
I just realized now he said brake fluid. WE DO NOT USE BRAKE FLUID AT THE DEALER TO CLEAN CARS. ;)
CrazyCawi
If you read the instructions on the goo gone, it says to not do it in the sun and not on hot paint.
says that on ky too but I dont listen :rolleyes:
Spunky99
Here is a picture of CC:D
CrazyCawi
I bet you do...
You can probably whistle really well too.
my whistles sound like wind blowing through the tree's ;)
I always say use powdered soap
totally kidding btw
FZ1inNH
I doubt anyone uses brake cleaner too. That crap eats plastic in a hurry!
Spunky99
CrazyCawi
The ingredients in brake cleaner will eat ABS plastic.
Brake Cleaner Ingredients | eHow.com
Acetone and ABS plastic powder is what ABS glue is made from and it eats the fairing on an FX6R and a Triumph Daytona and just about every other bike out there. It will also eat paint.
http://www.wynns.net/product_files/Brake Cleaner(10 litres) 57710 MSDS.pdf
What particular brand of brake cleaner do you use?
Maybe is is a cum baya green version that is dolphin safe?
definition of E-PWN
danieljardim
We use at the shop 3M. Next time we have a car that needs some clean up.. I'm gonna use it and record it.
Never tried on bike ABS plastic but bumper plastic and trim panels around the car we never had a problem.
Found this video.. at "4:00" he uses brake cleaner to remove glue out of car. and wolahhhh... Paint still there.
[ame=http://www.youtube.com/watch?v=fF98gvfBH5g]DIY: Vehicle Badging Removal/Replacement - YouTube[/ame]
threexcharm
What I did to remove stickers off my tank was a blow dryer. Heat that sticker up real hot, it becomes pliable, easy to remove. I then used WD40 to clean up the adhesive that was left.
bmw675
i use a chemical called 'cut-thru' to take decals off my bike, truck, helmets, tar/road oil off anything. also works good on cleaning the chain.
I would never use brake cleaner, that stuff scares me.
Spunky99
Is it this one?
Ingredient C.A.S.
Hydrotreated Light Naptha (Petroleum)
Propane
Xylene
Methyl Alcohol
Ethylbenzene
Toluene
Basically just naptha with some other solvents mixed in in small amounts. There isn't enough xylene, benzene or toluene to even get high off of. I wear a moon suit and respirator to spray catalyzed varnish and xylene with a hi vol low pressure gun so make sure the place is well ventilated. Xylene is very nasty stuff. Toluene is what got kids high off the old Revell glue for plastic models. They don't sell toluene to kids anymore.
Toluene works real good to clean off varnish.
Naptha ain't bad tho....
danieljardim
Is it this one?
Ingredient C.A.S.
Propane
Xylene
Methyl Alcohol
Ethylbenzene
Toluene
Yes. Looks like. I ll take a look monday on the can.
Spunky99
Update: I took the bike to a shop that did some major body work on my car after an incident. They told me they could sand the top of the tank and re-clear coat it, buff it, all for 2-3 hours of labor tops at $50 an hr.
