How long since you changed oil? Shifting gets rough when your oil starts to break down. How many miles on bike?
The sprocket cover?
I thought may be oil and changed it recently (mobil1 15-50) but didn't help. Bike has 25k mi.
Is the 15W50 for motorcycles? If not then that's your problem. You need a motorcycle specific oil for bikes. They provide the wet clutch protection that a normal oil does not.
No you don't. Just about any oil is adequate. There is one specific type not to use but I forget what.
You are getting ripped off at motorcycle shops if that is what you buy.
JASO MA
Japanese standard for special oil which can be used in 4-stroke motorcycle engine with one oilsystem for engine, gearbox and wet clutchsystem. Fluid is non-friction modified.
