WTNOTCH,,
Basically how I did mine.
Great minds and all that ....
WTNOTCH,,
Marthy did you go with the hypro setup?
Look quite drastic to me. I did about 6mm down and I felt like it was enough. Maybe I should try a bit more.
When I hear people call the FZ6R a beginner bike.. I laugh. Then again read below..
Cool, I look forward to seeing those numbers. Thanks.All I need to say is FZ6 Cams! I have PCV, Marthy Viper Exhaust and the FZ6 Cams and the mid range is mind blowing for a 600. I went for a nice ride tonight and fix the little flat spot on the map, mostly on the bottom end for drivability. I'll be busy next week at work but I want to get my ride on the Dyno ASAP to check some numbers and most than likely Dyno tune the bike.
No flat spot, no exhaust popping just perfect... like the bike should have been delivered!
So I've had my front end lowered about 2 1/4" for 2 weeks now and have noticed that it likes to hit turns a lot easier. Also, this past weekend had my first ride with speeds in the triple digits and I haven't noticed any shaking. So overall, I am happy with how low I went.
So at the higher position you were having issues with some shaking at triple digit speeds? Is that what you are saying?
No, others were wondering if lowering the front end would cause any issues at highway (or above) speeds.
If you do a search for Woodcraft Clip-Ons you'll find a review I posted. I lowered the front a little over 1.5 inches. The handling is superb and the clip-ons really look great.
No. I was very concerned at first so I lowered it a little at a time just to be safe. Now I can't believe I waited so long. It really feels like a different bike. You're bike looks awesome by the way.
