So I did a quick search of the forum and couldn't find anything specifically identifying this problem.
I am unable to get the bike into neutral when I am completely stopped while running. It skips from first and goes straight to second no matter how ginger I am on the clutch. I am however, able to get it into neutral when the engine is off. I have attempted to rock it, manipulate the clutch and throttle all to no avail when I am at a complete stop.
Of note I did change to the CNC clutch lever last night and that is when this issue started. I still have the OEM spec'd spacing in the clutch lever.
Any thoughts or suggestions would be appreciated. I can always switch back to the original clutch lever and see if it is an issue then and start from there. Thought I would ask while I am at work and before I get home today and start troubleshooting.
Could this be a sign of a needed oil change? I am at 1500 miles and the oil was changed at 400.
This would not be a huge issue, but when I go through the gate on base, I need both hands and would prefer to keep the bike on to aid in the flow of traffic.
I appreciate it guys.
