So I have a few questions...
(If you reply, please reference the question number in your reply - THANK YOU!)
(I'll defer the "Where do you mount your GoPro for the best dash view until after I snap and post new pics of my setup.)
Cheers!
- At what speed can you SAFELY downshift into first gear when coming to a normal stop? To clarify: this is without letting out the clutch to actually engage first gear, but rather this purpose is just to get the bike into first for the take off. Will I cause any premature wear or damage if I shift into first gear before I'm fully stopped like some other cars and transmissions? I noticed yesterday on my maiden voyage that if I waited until I was stopped before shifting that many times the trans/clutch were "locked" and I couldn't get past 2nd into neutral let alone first unless I rocked the bike back and forth to "unlock" and release the gears to allow me to shift into first.
- If you use a GoPro sticky mount on the gas tank, will it damage the paint or top finish?
- Why are so many car drivers idiots?
- Why do cars try to pull out and jump out in front of you EVEN WHEN THEY SEE YOU COMING and then try to speed away?!?!
- Instead of a double-0 "License To Kill", can I have a license to bitch slap stupid drivers instead?
- What's the seasonal bag limit for stupid driver mirror souvenir keepsakes?
- How long does your standard battery last in your GoPro Hero3 Black Edition?
- What video rez setting or combo do you use to record your moto adventures to obtain the optimal balance between rez quality and battery life?
- When filling up at a gas station, ever notice that guys shake the nozzle before replacing the nozzle back onto the receiver, but gals just pull it out and hang it up?
- Can you quickly blip rev match downshift with the STOCK clutch lever? Or do you need some kind of aftermarket lever with a shorter stroke?
- Do the air vents on the top of the RF1100 actually channel air to cool or head? Or just make a lot of extra noise?
- Does the TBR exhaust system get tiresome on long drives or commutes? Sounds so good, but worried that it would get annoying after a long commute every day, day after day...
- Is there a major difference in sound or exhaust note between the different TBR systems: black, carbon, titanium, aluminiumiumiummmm?
- Is the juice box, for all intents and purposes, basically a "must have" when getting a TBR?
- (Is the TBR even legal in the People's Demokratic Republik of Kalifornistan? I'm reading different things on the TBR FAQ vs. elsewhere on the intarwebs.)
- Anyone else have issues with Shogun right side engine mount bolt being too long and bottoming out? Or with the threads not turned far enough up the shaft closer to the socket head causing a different type of bottoming out?
- Do your knuckles get sore after riding for half a day? (First two fingers on clutch hand and ditto first two knuckles on gas hand.)
- When applying reflective or glow-in-the-dark rim tape, do you need to somehow remove the factory stripe first? (Or can you just tape right over it without fear of bleed thru?)
- How the heck do bugs get INSIDE your helmet visor if your visor is always shut tight? Chin vent?
Cheers!
