Slow Leak
MiltonDorkenhoff
Search, THEN post.
FitZ6R
Yup, like Jon said, some (but I doubt all) of the drop may be temp-related.
You could douse the tire, wheel, and valve with soapy water to see if you can detect a leak. If there's a puncture, it's clearly not a warranty issue, but the dealer might cover a leaking valve as a goodwill gesture. Sometimes all it takes is tightening the valve core.
As far as compressed air sources, you've already discovered that pay-by-the-minute is the worst way to fly. :eek: I have a self-contained, rechargeable jumpstarter / inflator that's pretty decent, and it won't kill your cycle battery. If you have room for it, a stationary, 120V compressor with a tank is a truly great thing to have. :)
Administrator
Staff member
I always check my tires when they are cold. You get a more consistent reading each time this way.
As for air pumps, I use the same tire pump that I use for my road race bicycle. It only takes a few strokes to get 6-10 psi into the tire. I don't like to use air compressors that you find at gas stations because there really is no way to regulate the flow rate and pressure from them.
MiltonDorkenhoff
Search, THEN post.
I use a bike pump and it works pretty good. I generally fill them up a little past where I want them and then use my gauge which has a bleed off button to drop it right where it should be.
I had a very slow leak in my truck tire just as you describe. I couldnt find anything wrong with it but decided to take it in before my cross country move. It did indeed have a nail in it. They patched it no prob. Free at that.
