Don't ride that thing until you get it figured out or your gonna do some serious damage to trans and engine. Sounds like maybe your filter or oil drain plug is loose. Take fairings off and check everything carefully. If you have rear and front stands that would be helpful.This is the first time I have having this issue. I cannot tell exactly where the oil is leaking from? Has anyone else had this problem? I'm guessing it's leaking from the oil filter that I changed a couple weeks back, but I don't know why it would start leaking now?
Can you take some high quality pictures of the oil filter and drain plug? Based on what you said it sounds like the gasket on the filter is bad but I would also look at the washer on the drain plug since that is a common culprit of oil leaks.This is the first time I have having this issue. I cannot tell exactly where the oil is leaking from? Has anyone else had this problem? I'm guessing it's leaking from the oil filter that I changed a couple weeks back, but I don't know why it would start leaking now?
the way the filter is wet on the lip...I bet you have two oil filter gaskets on there....Ok so I woke up this morning and took these pictures.
I looks like its leaking from the bottom of the oil filter so I tightened it as much as I could. I thought it might have been because I put too much oil in it but that doesn't seem to be the case. I'm going to take it for a very short ride to see if it still leaks after riding. Thanks guys. I appreciate you guys helping out.
That was going to be my next Q. Did the old oil filter gasket stay on the motor and now you have 2 gaskets which is a NO NO...the way the filter is wet on the lip...I bet you have two oil filter gaskets on there....
Must be out riding. LOLIt's now been two days since your short ride to check if it was still leaking. Any word?
Nice. I didn't think of that one and it likely would have gotten me one day. I'll keep it in mind for future oil changes.the way the filter is wet on the lip...I bet you have two oil filter gaskets on there....
