Stoppsladd
When are you getting a dyno for a custom map for the PCV? Otherwise you'll run too rich.
My plan is to do that soon.
But i also want to put it in a dyno and test it with the standard ECU and see how wrong or right it is. Maybe try to adjust the C1 and C2 values a bit to see how that works.
But i think i will do some more testruns during the week or during this weekend and take the plugs out n check colour of those. If they are black..then im running to rich, white ..to lean.. and light nut brownish well then its okay.
But i guess your right about that PCV and dyno run.
I just want to test what the bikes own system can deliver first. U now i also have the O2 sensor to help me out. that will adjust ECU down if its running to rich or up if running to lean. But on full throttle there is a closed loop (what i have heard) and is only running the ECU settings.
