i hope its water in tank
leprecaun jon
ESTABLISHED RESIDENT
leprecaun jon
I'm sorry I was mistaken in my earlier post what you are experiencing is smoke coming from your muffler bearings, and the only thing that can cause your muffler bearings to get hot enough to smoke is a carburetor belt slipping, both are very costly repairs but I'd be willing to do a favor for a fellow forum member and take it off your hands for $500. I know you will be loosing money but those repairs will cost in excess of $7500
It is obviously leaking blinker fluid into his flux capacitor induction link. Fairly simple fix. Get yourself a good, and I mean GOOD left handed metric screw driver and some lubricating adhesive. Pull off the shaft drive master link to get to the blinker fluid reservoir. Undo it with your trusty lefty metric screwdriver. Fill it with the lubricating adhesive so it can penetrate/lube and seal both the blinker res and the flux capacitor induction system. Put it all together and you should be good! Oh, make sure you use synthetic fluid. Only a noob would use anything else. A good one is called "Royal Gullible" . Think it comes in a purple bottle or something. Never used it myself though. ;)
While you are at it, get that crappy winter air out of your tires. These bikes require summer air only. Do the right thing.
klawson
I hear that if the blinker resorvoir is leaking and you don't want to
replace it, use about 18 inches of center-line tape (sticky side out).
See red
Center line tape only works for the non lubricated type. You need to use ribbon tape for the lubricated type, if you can get it with 30 guage and make sure you wire it for npn not pnp.
leprecaun jon
buzzbomb
txjames
buzzbomb
leprecaun jon
Mr Citrus
You know, since ya'll are being SO helpful to this obviously sincere, unlicensed rider, who happens to "own" a bike, that he's never ridden, but wishes to sell:
I've noticed that my bike goes FORWARD when I twist the handle-thingy BACKWARD!!! WTF!! I'm thinking maybe that the carb belt (previously pointed out to us noobs) is on backwards and it's making the carbs suck in when they should be blowing out. Yes, yes, I've taken the left handed Filipe's screw driver (paid a pretty penny for that one) and fully adjusted the belt tensioner overdrive modulator all the way to the North, just like it says here on the forum (use the search function). But no dice. *sigh*
LEGENDARY!
You actually made me feel bad for our previous posts, until I kept reading.
Blue-Sun
Chevyfazer
I'm wondering if coolant leaked into the oil via a crack in the block or head gasket problem. Even though it doesn't smell like traditional coolant coming out of the exhaust, someone might have replaced the coolant with water or Engine Ice or some other product that doesn't smell like traditional coolant being burned. Open the radiator cap and look for oil residue contaminating the coolant, then pull the oil dipstick and look for a white(ish) residue on it. If you have either situation, you probably have an oil/coolant contamination problem. At this point, you would need to track down whether it is a head gasket problem or a crack in the block or head.
I'd also top off all the fluids and see if you are losing coolant, if you are losing a lot of coolant and can't see a visible leak, you may be looking at a crack or head gasket.
No I'm pretty sure it's the carburetor belt slipping...
Sheesh... looks like we got a joker on our hands guys. What kind of response is this? All of us are giving this guy honest genuine advice and you come in with some smart ass response like that. Whats this world coming to where a guy can't just come to a forum and expect a realistic answer?
:justkidding: Love ya Blue!
