fazer1
Hello, I have a 2009 FZ6R that I've put different handlebars on that sit lower but more forward than the stock bars.
Everything was fine for a while, then all of a sudden (as the weather got colder) the clutch cable is sticking horribly to the point that I have to push it out to get it to engage.
Prior to adjusting the clutch cable at all, when I bought it used, the screw on the clutch cable that adjusts lever play was screwed out quite a bit. A few days ago I took the cable off and shot some lube down it until it came out the bottom where it connects to the clutch. After putting it all back together it's actually sticking worse now.
I'm wondering if the spring is shot that helps pull it back, if I need to remove an inch or so of the cable and it's housing due to the new handlebars, or if these things go out and something about the cable and it's tube have deteriorated so that it needs a new cable/tubing setup? I've attached some pics of my setup so you can see the bars and how they sit.
Also, if anyone recommends any after market brake/clutch levers and cable's please do share the name. Thanks.
