Sweaty Darwin. (10 character minimum so I added sweaty)Where abouts in Aus are you Rumpig?
Sent from my GT-I9505 using Tapatalk
If you read the link I posted about" Final Impacts Winter mod" he explains it. Basically there is a raised section on the timing trigger wheel that locates it on the end of the crank, you file one side of the raised bit so you can rotate it to advance the timing. Final Impacts bike is an FZ6 not an FZ6R, they do have different initial timing. He said 12 degrees total was to much.So, what needs to be cut out is my question
How is it up there, I'm from SydneySweaty Darwin. (10 character minimum so I added sweaty)
^^ not true...So your saying that if I file it down .021 in. Then rotate right, it will advance the timing 5degrees.
Genius. Would come in handyBought a spanner for a 9" angle grinder, fits the trigger wheel and the cam gears.
