Brake fluid
jgelack
I've had my bike a little over two years now, so it's time to change out my fluids. Can someone recommend a good brake fluid ? I've heard good things about Motul rbf600 and Amsoil. Any opinions about them ? Thanks
Chucker
Active Member
I used Motul and it seems fine. I changed to stainless steel lines at the same time, so can't really compare to the original fluid. I can say that I experience little to no fade at the track, which is about as extreme as it gets.
jgelack
Other than having a higher boiling point, is there any other differences between racing and regular brake fluid. Does racing fluid need to be changed more frequently? Would there be any problems running the racing fluid on the street?
blkbrd
blkbrd
alaskanflyboy
Premium Member
