Auxiliary Lights Options
I remove the little bar that hold the cable and wires together. Since I use the Renthal 787 handlebars I had to reroute everything, so the bar was useless for me. I use the two 6mm bolt (10mm socket) that hold the bar to fit the carbon dash. Look nice and clean!
That's pretty clever man...I have a voltmeter too but I didn't want to cut the plastic fairings...looks like I might have to borrow your idea :D
I know that Marthy pretty much solved it with his suggestion, but here is a more affordable solution:
Morimoto X.DRL - Accessories from The Retrofit Source Inc
Well, aren't those interesting. Slim and small. The only thing I would want in addition to something like that is the ability to position the LEDs so that if they are off at an angle then I can move each LED into the right kind of position. Otherwise those are pretty cool. Now I have to go take a look at the bike and see where I can mount them...
