Auxiliary Lights Options
I made a bracket and hook it up on the horn bolt. Worked good, just not sure if Ill install those the same way. Theyre a bit bigger...
Sent from my LG-P925 using Tapatalk 2
I'd like to see some photos of how you mount them once you do.
I could use some ideas for myself as I think I'm going to order a set of them for the ninja 1k
My headlight does pretty good for the most part but I would certainly like something better. I also want to setup a potentiometer to be able to vary the power like the clearwaters have to that I can have a variable setup and then once I get down the power levels I want I might just make a dual brightness switch to mount on bars so that I can flip them or I'll just integrate it into the hi\low switch. not sure exactly how I want to do all that just yet.
Martin, a friend made brackets and mounted these the the caliper bolts off the lower fork legs, thus squirrel lights!
They worked awesome!
Coleman Mach3 PS A/C
your link isn't working
But if money is not an option, here is where to look!
Adjustable, sleek, and just what you need!
Clearwater Lights High Powered LED Motorcycle Lights
They are not cheep but the best money can buy!
I mentioned those back on page 1. They would be nice but it's easily 2 times the price.
