adazine
Premium Member
Once you have all your fairings off and you have only the headlight fairing to remove, there are four screws indicated by the red hands and there is a really tough one to get to behind the speedometer cluster. Once that is removed, there are (4) 10mm bolts to remove that hold on the headlight.
You'll see the blank for the jewel light, I started with a center mark and a small drill before I worked up to the 1/2" size. I used a vacuum with a tube to get out any pieces that went into the light area.
Light inserted in hole - the white led fit snug so I wedged it in. The yellow one is loose so I'll need to use silicone to hold it in place
Testing the light
The white one before I took it off
The bulbs - didn't like the orange one, yellow looked better and brightest of all three
Both leds mounted
Hopefully I'll see more of these out on the road - Cheers !
Testing the light
Both leds mounted
