Bump this thread has been dead for to long, so read it and feed off of it new members lmao
There's alot off old but good info here. Thanks for the bump!Bump this thread has been dead for to long, so read it and feed off of it new members lmao
Glad to see your still here man! And its my pleasure this is a very useful threadThere's alot off old but good info here. Thanks for the bump!
Inline twin vs inline 4 =extra bits in the engine, longer shafts, wider motorI'm curious why fz6r is so heavy? when ninja 650 is only 170-180kg?
mine is 2009. Are next versions 210 kg too?
Your info is incorrect. The Ninja 650 is every bit as heavy as the 6R...however, this year the Ninja dropped a significant amount of weight, coming in at around 190 kg.I'm curious why fz6r is so heavy? when ninja 650 is only 170-180kg?
At that point, you're way better off buying an R6. I've thought of trying to have a rear swingarm made.... Its just not worth it. lolThis topic interests me the most.... That beshlugiduh frame! I wonder how much it would cost to bend a lighter alloy one... like you would find... on any... other bike
Also, I hear carbon fiber tanks can be worth the money for street since they don't break on potholes like CF rims or frames.
The battery is also a big one that's already been mentioned.
Other than that, just the standard stuff like exhaust... that frame tho, that's where the weight is, and it's top heavy weight, too.
That's the difference between us; you have stuff made, I make stuff.At that point, you're way better off buying an R6. I've thought of trying to have a rear swingarm made.... Its just not worth it. lol
Fender eliminator shaved 4.7lbs off my bikeI have noticed a lot of complaints about weight and power on the FZ6R. So here is a list of simple and not so simple mods to reduce weight and increase power. My bike is now around 451lbs with a full tank and that's still heavy but stock wet weight is 467lbs(470CA). Before mods we weighed almost 1/3 a ton together now nearly 30lbs under stock is a good 50+lbs under 1/3 a ton!!!
NOTICE: I still need the weights of these items
After: Full TBR exhaust system
Stock and After: Street Fighter Mod
After: Fender Elim kit
Stock and After: Mirror Replacement
Stock and After: Flushmounts
and anything else you can see that i didn't put on the list TY GUYS!!!
So without further ado:
Confirmed Stock and Aftermarket Weights = ""
Confirmed Stock Weights only = "**"
Unconfirmed Weights = "XX"
Stock Wet Weight = 467Lbs (470CA)
**#1----10lbs----TBR C/F Exhaust, A/F replacement, add PCV [+5HP +4ft/lbs +Coolness] Stock=18.4lbs
XX#2----10lbs----Street Fighter
#3----7.69lbs---Replace the Stock battery [+CCamps]
#4----3.25lbs---Remove Grab Bar [May Smash Tail in a Wreck]
**#5----3lbs-----Fender Eliminator + Inter-graded tail light [+Coolness] Stock=3.5lbs
#6----2.19lbs---Replace stock handlebars with some Apex Clip on Bars [+ Adjust-ability]
#7----2.1lbs----Remove your Tool Bag [-Field Fixable]
XX#8----2lbs-----Replace stock mirrors with pig spotters or bar ends [-Rear Vision]
#9----1.37lbs--Remove the stock bar ends [-Drop Protection]
#10---1.19lbs--Remove injection pump assembly and hosing installed Block off Plates [+Emissions]
XX#11--1lbs-----Smaller Aftermarket Sprockets [Faster Sprocket wear]
XX#12--1lbs-----Flush Mount blinkers [-Intention Visibility]
#13---.38lbs---Replace rear seat with a seat cowl and remove most of the metal from it[PITA]
#14---.38lbs---Replace Stock Kickstand with adjustable aluminum one [-durability]
#15---.1lbs----Remove Stock Front Reflectors [- Night Visibility]
End Wet Weight Max = 429.35Lbs SF= 419.35Lbs
Max -37.65Lbs Total Estimated Reduction without Street Fighter
Max -47.65Lbs Total Estimated Reduction with Street Fighter
My Current bike weight with 25-28lbs of fuel(aka full tank):
F238.8lbs+R213=451.8lbs
Some Weight Saving tips:
-Fuel weighs 6.1lbs per Gallon, a full tank (4.6 gallons) weights 28lbs, even if you only put 3 gallons in your bike that saves nearly 9lbs!!!
-You basically gain 1hp for every 8lbs you/your bike lose
-Diet Diet Diet!!! Your weight is your bikes weight!!!
-Make sure your fluids are not high...or low!!!!
-Take a **** before you ride....seriously!! "Each day, on average, people produce 1 ounce of poop for each 10 pounds of their body weight." so for a 200lb person that's 1-2lbs a day =P
PLEASE POST MORE WEIGHTS!!!
Anytime you replace something on your bike please post the weight of the original part and then the weight of the replacement part to add to the weight reduction chart
(Please post pictures of the part on the scale)
(Please weigh with a lbs/oz fish scale accurate down to the oz)
EDIT:
I recently made a Excel spread sheet that will calculate HP/Weight/HP:LB ratios for you =) called Perdurables FZ6R Weight Calc some pictures attached i attached it in a zip file to this thread. Keep and eye out for updates!!!
***Current Version 2.0
Got a write-up on how you did that? Did it change where your feet are much? If it did, did you swap out handlebars to compensate for the change in your footing? Thanks!I don't have a picture of the weight of these parts but....... I replaced both left and right footrests. These things weigh 4 lbs each and replaced them with rearsets from a 2005 R6 (each one weighing just 1 lbs.). I thought that was pretty good.
