installed another set of flushmounts
also just did my 600 mile oil change! it feels soooooooo good now
I painted a few parts can you tell??
Sent from my PantechP9070 using Tapatalk 2
Actually, I read something a few weeks back about if you low side at speed, frame sliders can do more damage by flipping the bike. I think the link or article was even on here maybe. I've actually been considering taking mine off because of it.....
If I low side I hope my bike gets demolished so I get a new one from insurance. :)
keeping my frame sliders.
Any situation where you're going fast enough to happen to catch a slider causing your bike to flip would more than likely total your bike anyway. The odds of that happening are pretty small, whereas the odds of you dropping your bike or wrecking at fairly low speeds and the frame sliders saving you from massive repair bills are substantially higher.
I agree with this. I would think that on a street bike, it is probably more common to have your bike go over at a standstill or slow speed. (no statistics, just my opinion). In which case, sliders will definitely benefit.
Now alot of people at the track do have the opinion that sliders can make things worse at high speeds. I would say bikes with sliders on at the track is about 50/50.
Any of y'all got any close up pics of where the sliders bolt up to? On the fz6 they bolt to the aluminum frame tang that extends down as part of the motor mount. Dead center in this picImageUploadedByTapatalk1350083200.487082.webp
There has been quite a few people who bought extended frame sliders and when the bike goes down the extra length adds extra leverage and breaks the slider off along with the frame, and one the frame is broke the bike is totaled 90% of the time. I think that would be real hard to happen on a steel frame bike, but something that y'all might want to consider that I haven't seen anyone mention yet is the bolt. I've seen lots of "good" sliders that have cheep bolts and that is the 1st thing that fails. If you prefer the slider to break off then you might want to stay with a cheep bolt but if you would rather it stay on you might want to double check the bolt and find out what it is. Me being a metallurgist I would personally go with a mid grade bolt grade 5 or property class 9.8. They offer enough sheer strength to protect from breaking in a low speed fall but not being super strong and possible not breaking in a high speed fall. Here's a link for some basic bolt identification http://forums.pelicanparts.com/uploads9/Head+Marking+Chart1168989552.jpg
I have T-Rex sliders... no cut, and multiple mount points.
The bolts they come with are 12.9, so, they have to be torqued in and used with Loctite, but, they have a ridiculously high shear strength from what I understand (however, it *is* possible to shear them, since I sheared on off with initially *wrong* instructions).
They're mounted to a bracket, which is then attached to the engine mount at three points... Good quality build. Hope to never find out just how good...
Yeah 12.9 are really strong and with 3 mounting points I don't see any issues, they sound like a really good slider. And FYI the sheer strength of a bolt differs from the tensile strength, the tensile strength more or less refers to the force that tries to pull the bolt apart or the force it can hold parallel with the bolt (what most bolts are made for, up and down or in an out) while the sheer strength is the force it can stand from a perpendicular load, like a slider hitting something on the ground and "sheering" off.
got my seat cowl painted at work and installed.
you can see whole bike pics on my thread:
alh081's MOD thread
