Lowering front end for more aggresive look?
sbastien82
I don't think this is a repost..there is alot of post on lowering with the links but I want to know if anyone has just lowered the front ends the way they describe here?
"The bike’s front end sits unusually high, and along with an odd appearance it also reflects in handling as the Yamaha isn’t the tightest liner. Obviously the budget conscientious forks have a lot to do with its handling capabilities, but a few turns of the wrench helped improve both aspects.There is plenty of room beneath the handlebar to allow for the forks to rise through the triple trees, thereby lowering the front end for a more aggressive stance and more weight bias on the front, allowing for slightly quicker turning ability without creating any skittishness. Gotta love the freebie mods."
I'd love to lower the front end of my bike without the links. Thanks for lookn
bobby bo bonsin
Just make sure its even on both sides and enjoy. Best appearance mod you can do on this bike.
wby0001
Those that have done this mod...do you think lowering the front 2" could cause the bike to bottom out while going over speed bumps? I have to go over a couple every time I leave and come back to my apartment.
Personally, I haven't scraped bottom over speed bumps.
The photo kinda shows the ground clearance with the bike being lowered 2.5" up front.
cavcuz05
How are the cables i lowered mine about 1.5in and the cables are a bit tight
Bradlockard
dropped my bike 1.5 inches in the front. everything is ok except the horn and its bracket WILL CONTACT your front fender causing damage!
Mitch21
A good way to check how much u can lower is to look at the dust marks on the forks in between the triple trees. This is how much play you have in lowering as your suspension hasn't been used in that area where the dust is. This will differ with each bike with various riders and riding styles. And if you lower the bike using less than the length of the dust area you shouldn't bottom out. Hope that made sense. :zombie:
WhiteFZ
I just lowered mine 1.25 inches in the front. Should have come like this from the factory. Turns in great now.
Stitchoholic
Does this lower the height of the bike at all? I'm a little short (I added my profile pic.....but couldn't figure out how to add a pic to this post) and will be getting the lowering link, but until I do, will this lower it at all?
Yes, I am a vertically challenged rider also, this allowed me to get a lot better footing.
