Yamaha oem center stand
Stephenfz6r
How much was the stand?
:eek:
Uno979
Thuper Moderator
Premium Member
Totally forgot about the stand and forgot to call yamaha.
I just took this pic as you can see lots of parts in bags with no instructions.
The bottom of the stand looks different from the mono tech one.
The hardware looks high end though. Bolts already come with lock tight stuff.
Bushings are heavy polished.
Being in canada I think it would have cost me same to get mono tech with shipping.
Dealer gives me discount I think $130.
Here's pic of my parts jumble.
I will post in mod section once installed hopefully this weekend.
Heineken
bikerboi
What is the point of using a center stand?
Still very new to the motorcycle world. :confused: I'm confused what is a center stand used for?
Diluted
Super *********
MikeN02
Some bikes have a center stand, some don't. It's a 2nd stand underneath the bike and is even more sturdy than the side stand if you park it.
Now it's easy to do maintenance on the bike because the rear and the front is off the ground, instead of buying a rear stand.
Drawbacks of it is a little extra weight on the bike, if you get an after-market exhaust for the FZ6-R I don't think you can use it.
It's kind of hard to use on but once you get the hang of it it's easier.
Stephenfz6r
It is a piece of equipment that should have come with the bike which you would take off after you drag into the asphalt when you get really good at cornering.
:rant:
Rabbitman109
Lumen Junkie
Update.
Had a chance to call Yamaha.
They don't have instructions available for this kit?
Kit was meant for the yamaha dealer to install?
Yamaha is going to send me a sketch via email.
I hopefully will get a chance to install tommorow.
Looking at the other motech stand it seems square in the picture. The yamaha has more curves so I hope this thing fits.
Seems like I'm going to be the test case so I'm planning on taking some pics for whoever is interested.
