Put smaller blinkers on few years back and they only had two wires so the running light side of the blinkers did not work (need 3 wires), so came up with and idea as to what to do with the other wire. Bought some Eagle Eye LED lights and mounted them in the side faux vents.
Bought factory style connectors so looks like factory install, lights are held in with 3m double sided tape (custom made mount) so can remove without damage to faux vents, soon as the key is turned they light up so can be used without headlight on.
