Was replacing some stripped bolts on the right side engine casing and noticed that there is oil on the threads. The oil is black and looks a bit gritty, more like grease than leaking engine oil. Is this normal or should I have the mechanic look at it? Has anyone who has installed the R&G engine sliders noticed the same thing? You have to replace three engine bolts on each side to install them.
