LED flashers - Hazards faulty
Lilday
I've found the following threads which offer some info:
Motodynamic intergrated tail light - hazards not working? - Yamaha FZ6 Forums - International FZ6 Motorcycle Community Forum
Hazard lights - flash once then stop - Yamaha FZ6 Forums - International FZ6 Motorcycle Community Forum
Hazard lights not working after fitting mini indicators ? - Yamaha FZ6 Forums - International FZ6 Motorcycle Community Forum
My Hazard lights don't work (after LED indicator installation) - Yamaha FZ6 Forums - International FZ6 Motorcycle Community Forum
Motodynamic tail light spliced with led turn signals, malfunctioning - Yamaha FZ6 Forums - International FZ6 Motorcycle Community Forum
But none of them have a definitive answer or anything I can work with. So I'll ask you guys.
I've just installed these blinkers on the front:
New Genuine Yamaha Carbon LED Indiators YME-W0789-20 YZF R1 R6 R125 Flasher | eBay
They include the in-line resistors.
I have a moto-dynamic rear tail-light with integrated blinkers. This also has an in-line resistor.
Motodynamic tail light & Standard front blinkers = No problems.
Motodynamic tail light & One LED front blinker & One Standard front blinker = No problems
Motodynamic tail light & Both LED front blinkers = Problem.
The problem - My hazard lights flash once and then stop. I then have to wait 3 seconds before I can use my blinkers or try the hazards again.
It seems the hazards are over-loading the bike and cutting out for 3 seconds.
Any ideas on a fix? The blinkers work perfectly fine, it is only when I try the hazards then it fails.
Thanks guys.
latony007
you may need another Brit or Ausie to answer that question since the braniacs at Yamaha decided not to include the hazards lights in the north American version.
MiltonDorkenhoff
Search, THEN post.
Xjman
Hazards not working
The watts are too high do not exceeded 10 watts that's the problem had the same problem changed bulbs to lower wattage and sorted
:cool:
Bert-Aus
Maybe try a resistor on the master line for indicators (IDK?)
