Do any of you guys going so far on a tank use a center stand? I know when I fill mine up using the center Stan vs regular side stand I can get quite a bit more fuel into the tank which results in me hitting one bar at about 40 km more on the ODO just because of more fuel in the tank. Next time I'll make a note of the exact difference.
lol hadn't thought of that, next time I fill up I'll put it on the stand first. Only problem is my 140 lbs struggles trying to get the bike on the center stand.. it's usually a tug -> grab front brake -> tug again -> repeat until it's all the way up
You're doing it wrong
1. Get off bike
2. Place right hand on rear grab handle
3. Place right foot on stand pedal bit
4. Push down lightly with foot and get both feet of stand level contacting the ground.
5. Simultaneously push hard down with your right foot and lift the bike up with your hands.
Should pop up nice and easy.
To get it back down
1. Place right foot on stand pedal bit.
2. Push down initially for stability with your right foot, lift bike up and forward. left hand on bars, right hand on rear grab handle.
3. Pause a second once down to stabilise, kick down sidestand if you want (i always do in stations, slippery floors and stuff)
4. Get on.
As for capacity difference it's about 2.5 litres by my reckoning. I get in 13ish on side stand 15ish on centre and as 17 ish is full it's about right.
Sent from my GT-I9000 using Tapatalk
No you don't basically do the same thing. You don't push on the stand foot pedal thing and try to roll the bike rearward up on the stand....you put all your weight down on it and push the pedal down hard, using your right hand on the rear grab handle as leverage. Like you're trying to pull your hand straight up and push your foot straight down apart from each other at the same time. It sounds funny but you don't pull back on the bike at all.... the leverage of the foot pedal "arm" will rock the bike up.I'll have to try that tonight xD I have been getting off the bike, use right foot to push the stand down a bit.. make sure it's on both feet.. and then with both hands on the handlebars.. try to pull it up while pushing on the stand foot pedal thing with my right foot. It sounds like you are saying to basically do the same thing, but have left hand on left handlebar grip and right hand grab the rail thing under the passenger seat? Maybe that'll just give me the leverage needed to pull the bike up. I'll let you know
