Can't wait for my first track day, Texas World Speedway Sept 1.
(of course, there's a bit of prep work the bike will need)
Look right in front of my knees... I've had the Puig Pro Frame Sliders since I got the bike.take it slow 1st couple sessions, then go balls out.
can't tell if you have frame sliders?
I went with Sportbike track time, they are mainly here in the midwest and south. In novice group, the first 3 sessions of the day were all follow the leader with your instructor (groups of 4-5). 1 session was to work on lines, 2nd was break and throttle control, 3rd was body positioning. after lunch they opened it up. I learned a huge amount from following the instructor, and feedback on what I did/could do better.Some track day groups will have a separate group at the start for people whove never been on a track. They take you out with an instructor for an orientation. If they do that at yours its a huge help
Sent from my SPH-D710 using Tapatalk 2
https://www.facebook.com/TrackTacticsIt is organized by TrackTactics.com (on sept 1st-2nd)
The same goes for your toe sliders and sidestand. Be prepared for them to touch. I remove my sidestand for track days because it always touches. It's easy to do and takes it out of the equation.As they say, "Don't chop the throttle or stiffen up" if the pegs touch, you can stay cool and let it grind or slowly roll off the throttle. The instinct is to back off and pick it straight back up, but that can make you run slightly wide sometimes.
