For those that have the Givi FZ364 rear rack for the FZ6R I have a little bit of a question for you!!
On installing my rack today and trying to put the bike back together, I noticed that this has impacted my seat height adjuster plate.
I use the "H" setting, but now I can not get the plate to fit. It only works on the "L" setting. The problem is, is with the increased width of the bracket that the plate slides around on both sides at the back of the seat on the "H" setting, I can not get it through both brackets.
I believe I am most likely going to have to mark the plate and *Dremel off a little bit of the plastic to make this gap bigger.
What have you done to resolve this? I cant comfortably go to the "L" setting being 6'4.
If needed I will take a picture tomorrow when it is light out again. Thanks for any input!
