Is your garage heated? Sounds odd that your garage would have so much humidity in the winter. I live in PA and don't have that problem. Garage isn't heated/air-conditioned, but stays consistently cool (never freezing or real hot) . Never had a problem with moisture.Which one do you use? Everything in my garage is covered in a film of water. Tools, toolbox, motorcycle, car, everything.
I think the ventilation is blocked right now, and that's an issue. Also noticed that it occurs most frequently when the temperatures drastically change.Is your garage heated? Sounds odd that your garage would have so much humidity in the winter. I live in PA and don't have that problem. Garage isn't heated/air-conditioned, but stays consistently cool (never freezing or real hot) . Never had a problem with moisture.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
What is that black magic you speak of?whats humidity? Does that have something to do with that white stuff that falls on the ground over there? LOL
Dump a bucket of cold water over your head... see if it computes then. lollmfao!!! this thread does not cumpute I just cannot comprehend lol
Where are the pictures of proof? nm I don't want to see that!Did not work
Sent from my one and only iPhone 5 using Tapa 2 da talk
...Try, try again.Did not work
