The owner's manual (page 7-34) says that a special type of battery charger is needed to charge the battery:
I looked on CycleGear's site and nothing jumped out as "constant-voltage". Does anyone know what I should be looking for?
Thanks
To charge a VRLA (Valve Regulated Lead Acid) battery, a special (constant-voltage) battery charger is required. Using a conventional battery charger will damage the battery. If you do not have access to a constant-voltage battery charger, have a Yamaha dealer charge your battery.
Thanks
