steelrider
Anyone know if there is a way to adjust the brake pedal height? My bike is a 2014 model.
You should be able to adjust the linkage for pedal height. The linkage is attached to the master cylinder just loose up the lock nuts adjust linkage rod and tighten down lock nuts and you should be good I go.Anyone know if there is a way to adjust the brake pedal height? My bike is a 2014 model.
