+1We used to use nitrogen in the tires when we were racing stock cars because you get a more consistent change in tire pressures and less moisture. But like Robert mentioned, it's expensive and not really worth it for street use.
thats the only time we used it as well, and agree 100%.We used to use nitrogen in the tires when we were racing stock cars because you get a more consistent change in tire pressures and less moisture. But like Robert mentioned, it's expensive and not really worth it for street use.
You must've gotten the helium version!...it's like riding on a cloud...
(no i dont)
Darnit you stole my post!You must've gotten the helium version!
Anyone ever tried a wheelie with helium in the tire? Can't get it to go back down!
PV=nRT baby! :steve::steve::steve:As a 25 year veteran airline Mechanic I can tell you the only reason nitrogen is put in aircraft tires is to eliminate water vapor in the tires(which could freeze in flight then unbalance the tire for landing). The pressure is measured in pounds per square inch(PSI), it is irrelevant what gas is creating the pressure only that it is correct. Corrosion prevention is a secondary benefit of using Nitrogen. As noted before the air we breath is 78% nitrogen and the nitrogen you buy was derived from the air from using a separator which most air lines have to fill tires and tire filling bottles. If you were to fill a tire on a day that was very humid and assuming the compressor tank had filled with humid air then you could expect to have some liquid water in your tire. A good source of compressed air would have a dryer assembly that basically eliminates that moisture. A good garage would have dried air supplied to their equipment like we do at the airline. There are 5 gas laws that talk about compressibility and temperature and expansion if you really want to see how minuscule the related density difference is between breathing air and pure nitrogen.
GEEK!!! :rof: :rof:PV=nRT baby! :steve::steve::steve:
I was thinking the same... now we're talking 99vengeur's language....GEEK!!! :rof: :rof:
GEEK!!! :rof: :rof:
You guys kill me!! :rof:I was thinking the same... now we're talking 99vengeur's language....
get back to making mutants and stop thinking about gas laws...
only law I have about gas is with my kids in the van.......
roll down the window :rof:
You're not a geek for knowing it, but for being so excited about it that you put the :steve: 3 times after it.You guys kill me!! :rof:
Jon, it's the simple things in life....You're not a geek for knowing it, but for being so excited about it that you put the :steve: 3 times after it.
