Exhaust install help
wachikinow
Oklahoma
I've gotten plenty of help from you guys already for a few years. Which I thank you for, but I've finally ran into a snag and couldn't find much info on it. So here is my first post.
The bike is a 2009 FZ6R.
I had to replace an oil related part, which required me to remove the (stock) exhaust. Everything was going smoothly, but I cannot get these headers lined up properly to save my life! I just can't get those bastards to go in any further!
I've tried a few times times already thinking "Yes! Finally!", I start her up and by the sound of it I can tell there's an exhaust leak. I gave a small rev to make sure, and she poots herself to sleep.
As for the method I'm using, I grease up the gaskets so they'll stay up in the exhaust port. I have a friend or jack support the unattached muffler while I line up the headers. We jiggle it around to make sure it is surely positioned correctly. Then I hand tighten all the nuts, you know, going a little bit on each one until they're all tight. Then the muffler bolts are hand tightened, and then the header flange nuts are tightened to the 14ft/lb spec.
What sort of tips do you guys have for this?
Thanks a lot, everyone!
Yes!!! I freaking got it!!! :D
I tried my best at not going beyond 14ft/lb, but I did end up bending a couple of the flanges a little bit...
But shes running fine!
Thanks again, guys.
....I grease up the gaskets so they'll stay up in the exhaust port....
Is the grease just the regular old black stuff? Is there anything else that I might use to hold the gaskets in place while the header is fitted?
Thank you in advance!
