Work out on a body part that doesn't hurt......like legs!Dude it's been 5 days and my lats are still sore. lol... Couldn't workout again until they heal. It's been so painful I couldn't even sleep well unless I slept on my side or on my back. lol. >.< It is hurting a lot less today tho. So outta shape
What exactly did you do to get them this sore?Dude it's been 5 days and my lats are still sore. lol... Couldn't workout again until they heal. It's been so painful I couldn't even sleep well unless I slept on my side or on my back. lol. >.< It is hurting a lot less today tho. So outta shape
He worked out for the first time.....In a long time..What exactly did you do to get them this sore?
Sent from my one and only iPhone 5 using Tapa 2 da talk
Yea still curious what he did. I've never had my lats sore maybe I'mHe worked out for the first time.....In a long time..
Do you even lift?Yea still curious what he did. I've never had my lats sore maybe I'm
Missing something.
Do you even lift?
Do be cautious to not overwork them because its as bad as underworking. Working them for hours sounds like alot of reps. If your trying to build then its low reps high weight. I pick 2 muscle groups a day and do 3 lifts for each group. With fillers in between rotations (2 sets, one from each group) to add recovery time for the next rotation. Typically my workout is over within 1.5 hrs. But ocassionally you do want to do high reps just to confuse the muscles.apparently not hard enough.
Dude I isolate muscles and work them out for hours and I might feel a little tight the next day but not sore like I should be getting. maybe I consume to much amino acids?? idk why but I'm never sore enough.
Hours? dude, an hour in the gym is long enough. After that, your body produces cortizol which will destroy any gains you have. Work out hard with little rest between sets with moderate to heavy weight to see the most gains. If you are not in pain, then there is no gain.apparently not hard enough.
how often do you change the exercises? Changing reps and weights helps prevent plateau but you can also change the exercises; still working the same muscles, but either in a different range of motion or different activation altogether. You can also change the speed at which you lift.
And you're not going to be "noob sore" anymore if you've been lifting for awhile. Unless you try something very different from your routine. The only time I am "sore" is when I lift heavy, or when I go do a crossfit workout. Lightweight supersetted stuff burns at the time, but it doesn't make me sore anymore either.
Today's completed routine:
Squats, Front Squats, V-Squats, Angled Squats, Leg Press, Angled leg press & Calf Lifts. Sat in the sauna for 20 minutes, Then jumped in pool & swam for a few.
Worked out for exactly 53 minutes not counting sauna & swim.
Today's Overall Diet:
Steak, Chicken, Egg whites, Fish, Spinach, Carrots, Almonds, Tuna, Orange, Rice cakes, Peanut butter, black coffee, 1 gallon of water, 1 gallon of milk & 1 lolly pop.
Cheat meal: Either Pizza or.....well, probably pizza...
They need to make taller benches for youThis is me lifting 315 Lbs on the Bench Press. My PB 1RM is a little higher but I had just got back from a long motorcycle ride a day earlier so was still a little tired. In a few months I will be repping 315 LBS like nothing as I head towards my goal of hitting 405 lBS.
enjoy:
Bench Press 315 Lbs - YouTube
Then here is me doing a drop set by lifting 225 LBS @ 10 reps..This was my 4th set
Bench Press - 225 LBS - 10 Reps performed by me - YouTube
Now here, I am on the Incline Bench press, doing a warm up set of 135LBS at 10 reps. I did a total of 4 sets.
Incline Bench Press - 135 LBS - 10 reps warm up set - YouTube
Now, if your going to hit the incline, then you should also hit the decline. I did an over extended rep set of 20 reps with 135 LBS to loosen me up before adding weight. This one is a little tough for me because I am so tall that the equipment is not quiet big enough for me but here you go.. I did 3 sets total.
Decline Bench Press - 135 LBS - 20 Reps - YouTube
Now, since your triceps are on fire at this point you might as well burn them out for maximum gains before your body starts to make cortisol.
I did 4 sets for the tri-s by doing tricep Cable Push downs..
Triceps Push down cables - 100 lBS - 15 Reps - YouTube
I did not record all of my exercises today because I got focused & stopped playing around with the camera but will record other exercises later.
My total workout today consisted of: Flat bench press, Incline bench press, Decline bench press, Flat dumb bell press, Incline dumb bell press, Shoulder press & tricep cable push downs.
Then I had a decent after work out meal... Sea attached photo...
